[GRASS-user] Problem with Grass CVS
Markus Neteler neteler at itc.it
Mon Jul 31 06:03:15 EDT 2006
Dear Darrel Maddy,
I have fixed that bug yesterday:
Label -> label
file "/usr/local/grass-6.1.cvs/etc/gis_set.tcl" line 908
I have re-run now the job to create the src and binary snapshots.
But you could better update from CVS directly without transferring the
entire snapshot again.
Markus
Darrel Maddy wrote on 07/30/2006 10:33 AM:
> Dear all,
> I have just taken delivery of a Dell 490 workstation (dual xeon) which comes complete with an install of RHEL4. I spent a few happy hours yesterday trying to install the latest CVS. After Fedora 5 and Ubuntu I must say that RHEL seems a little antiquated!
> After assembling the libraries I attempted to complile the source. The ./configure seems to suggest all is well but make throws up a number of errors. When I installed the binary and ran the executable I received the following message:
> Starting GRASS ...
> Error in startup script: invalid command name "Label"
>     while executing
> "Label .frame0.frameMS.label  -anchor {w}  -text [G_msg "Accessible Mapsets\n(directories of GIS files)"] "
>     (procedure "gisSetWindow" line 88)
>     invoked from within
> "gisSetWindow"
>     invoked from within
> "if { [searchGISRC $gisrc_name] } {
>    gisSetWindow
>     (file "/usr/local/grass-6.1.cvs/etc/gis_set.tcl" line 908)
> /root/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or directory
> ERROR: /usr/local/grass-6.1.cvs/etc/lock:
> root is currently running GRASS in selected mapset. Concurrent use not allowed.
> Is this a missing library? If so which one?
> Any help would be appreciated.
> Many thanks
> Darrel
> My configure options are:
> CFLAG=" -g -Wall" LDFLAGS="-s" ./configure \
>   --enable-64bit \
>   --with-libs=/usr/lib64 \
>   --with-cxx \
>   --with-freetype \
>   --with-freetype-includes=/usr/include/freetype2 \
>   --with-proj-share=/usr/local/share/proj \
>   --enable-largefile \
>   --with-tcltk-includes=/usr/include \
>   --with-opengl-libs=/usr/include/GL \
> Prof Darrel Maddy
> Chair of Quaternary Science
> University of Newcastle
> +44 191 2226440
> Skype VOIP: ProfMaddy
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
