[GRASS-user] v.to.rast error
Markus Neteler
neteler at itc.it
Mon Jul 31 06:05:04 EDT 2006
Jacolin Yves wrote on 07/31/2006 11:03 AM:
> Ok, I know why I get this error (char type). What I don't understand is why my
> column is in char type ?
This was defined during import and depends on the data source.
Could you post:
v.info -c clc_2000_centre
> If I want to change this, do I need to use db.execute to create a new column
> and then copy data from the first column to the new one ?
Right.
> Thank you for your tips !
> Y.
> Le Lundi 31 Juillet 2006 10:41, Jacolin Yves a écrit :
>> Hi,
>> I would like to rasterize a vector layer. I tried :
>> v.to.rast input=clc_2000_centre layer=1 output=clc_2000_centre use=attr
>> column=CODE_00 value=1 rows=4096 (using the GUI).
>> I got this error :
>> Column type not supported by db_select_to_array()
>> The data of this column is integer, eg : 123, 234, 623, ...
>> Do you have an idea ? Thanks,
>> Y.
