[GRASS-user] could the region change between 2 commands in a
single Bash script?
Maciek Sieczka
werchowyna at epf.pl
Thu Jun 1 14:27:18 EDT 2006
On Thu, 1 Jun 2006 17:31:07 +0100
Glynn Clements <glynn at gclements.plus.com> wrote:
> you can force the use of a different region by setting either
> of the environment variables WIND_OVERRIDE or GRASS_REGION.
> WIND_OVERRIDE should be the name of a saved region (created with e.g.
> "g.region save=..."), while GRASS region should be a complete region
> definition in the same format as a region file except that newlines
> are replaced with semicolons.
> E.g.
> region=myscript.$$
> g.region save=$region
> export WIND_OVERRIDE=$region
> g.remove region=$region
Thank you Glynn! This will help.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
