FW: [GRASS-user] Problem with Nviz : first post
Prof Darrel Maddy darrel.maddy at ncl.ac.uk
Wed Jun 7 08:51:48 EDT 2006
Many thanks for your suggestions.
"What happens if you issue the 'nviz elev=elevation.dem' from CLI?"
"Please copy/paste the text output here (tcltk GUI tends to hide some low
level errors, like segfault, from the user)."
GRASS 6.0.2 (spearfish60):~ > nviz elev=elevation.dem
Loading Data
Loading Data
translating colors
recalculating normals...
Segmentation fault
"Do you know that you must set the region to match the elevation.dem first
(g.region rast=elavation.dem) for NVIZ (and most any other display module)
to be able to display it?"
I was not sure whether you were saying these were related and so I followed
the instruction with the following result.
GRASS 6.0.2 (spearfish60):~ > g.region rast=elevation.dem
Loading Data
Update elev null mask
Loading Data
translating colors
Segmentation fault
OK. Can you enlighten me as to the possible causes of the Segmentation
fault?
Very many thanks again for your help.
Darrel
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060607/d6618308/attachment.html
