[GRASS-user] mapcalc NULL issue
    Carlos "Guâno" Grohmann
    carlos.grohmann at gmail.com
    Thu Jun  8 08:15:29 EDT 2006
OK, i did with:
test=if(A==0|||isnull(A), B,A)
instead of
Note the "III" operator
Carlos
On 6/8/06, Wolfgang <wollez at gmx.net> wrote:
> out of the manual from r.mapcalc
> Example: The users wants the NULL-valued cells to be treated like zeros.
> To add maps A and B (where B contains NULLs) to get a map C the user can
> use a construction like:
> C=A + if(isnull(B),0,B)
> Cheers
> Wolfgang
> Carlos "Guâno" Grohmann schrieb:
> > Hello all.
> > I have two rasters (SRTM_V2), one has data on the continental area,
> > with zero values in the ocean. The other (SRTM_30 PLUS) has values for
> > all region. I'd like to patch them, using r.mapcalc, like this:
> > if srtmv2==0 OR srtmv2==NULL, then use value from srtm30plus, else srtmv2.
> > I tried this in mapcalc:
> > test=if(A==0||isnull(A), B,A)
> > but it didn't work. the result was the same as test=if(A==0, B,A).
> > So how can I manage to get the condition for zero and null at the same
> > time? I mean, I can do this in a single operation, right? Or do I need
> > to make two operations?
> > cheers
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
