[GRASS-user] Freetype fonts in gis.m
Michael Barton michael.barton at asu.edu
Sat Jun 10 01:53:55 EDT 2006
I correct myself (had to check into how Cedric had changed it).
D.font romans is run once per rendering session, not once per layer
D.erase -e is run once per layer.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sat, 10 Jun 2006 02:22:16 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, <grassuser at grass.itc.it>
> Subject: Re: [GRASS-user] Freetype fonts in gis.m
> Michael Barton wrote:
>>> 2. gis.m provides no guarantees as to the order in which layers are
>>> rendered. If a command changes the font, whether other commands use
>>> the default font or the changed font depends upon the order in which
>>> the commands are executed.
>> The layers are always rendered and composited in bottom to top order in
>> gis.m.
>> Between each layer rendering, it is necessary to run a d.font command or no
>> text will render. Currently this defaults to d.font romans. It could be set
>> to a variable which, in turn, could be set by d.font.text or
>> d.font.freetype.
> You're still restarting the driver for every layer?
> Whilst inefficient, that does at least simplify the font issue.
> For now, it's simpler to keep the font handling entirely within gis.m,
> i.e. provide a user option to control the font used at startup
> (ideally, also provide an option to use freetype fonts).
