[GRASS-user] Freetype fonts in gis.m
Hamish
hamish_nospam at yahoo.com
Mon Jun 12 03:23:41 EDT 2006
> > Adding a d.font.freetype "cmd" to the gis.m command list will run,
> > but doesn't seem to have any effect on the rendering.
> You have to add it below the layer which draws the text (so that it is
> run first), and you have to force it to be executed, e.g. using the
> "Redraw all layers" button.
> If the layer containing the text is re-rendered but the
> d.font.freetype command is skipped because the layer hasn't changed,
> the text will use the default "romans" font instead.
ah, ok, d.font.freetype works as a gis.m "command layer" if I flush the
image cache.
thanks,
Hamish
