[GRASS-user] cs2cs question
    gary
    lists at lazygranch.com
    Mon Jun 12 04:43:13 EDT 2006
Thanks. On suse 10.0, the file was in the same location. Double
checking, it turned out to be WGS84 and 11s, so I used epsg:32711.
Output is:
513581.64 14424601.96 0.00
603821.51 14023544.20 0.00
Using garmin mapsource
11 S 513582 4224602
11 S 603822 4023544
More or less a match if you ignore the "1" in 1442601.96 and 14023544.2
David Finlayson wrote:
> You find the init parameters in the proj directory. On Ubuntu they are
> here:
> /usr/share/proj
> Open one of those files with your text editor and look up the number
> for the projection you need. Then when you have found it feed it to
> the init parameter like this:
> +init=<filename>:<projection number>
> Assuming that you do need to convert to UTM zone 11, NAD83 search for
> the line in epsg that begins with this:
> # NAD83 / UTM zone 11N
> <26911>
> so the init would be +init=epsg:26911
> Keep in mind that there are HARN grids, and many versions of each
> ellipsoid. It is worth searching for UTM zone 11N multiple times to
> see all the possibilities. Only one of them is probably what you want.
> On 6/12/06, gary <lists at lazygranch.com> wrote:
>> From
>> <http://cemml.carleton.ca:8080/OGUG/Members/smitch/raster-elevation-data-in-grass-workshop>
>> the cs2cs program command line example is:
>> cs2cs +proj=latlong +datum=NAD83 +to +init=epsg:2146 -r << EOF
>> ? 45d30'0"N 76d0'0"W
>> ? 45d15'0"N 75d30'0"W
>> ? EOF
>> 343875.12       5040130.27 0.00
>> 383295.32       5012713.16 0.00
>> Now I want to convert from latlong to UTM. However, I can't find the
>> "init" parameter in the cs2cs documention. [Oh, I'm sure it's pilot
>> error, but I did read "Cartographic Projection Procedures for the UNIX
>> Environment—A User's Manual" )
>> The UTM will be in zone 11.
>> 38.16922 -116.84495
>> 36.35138 -115.84293
>> Could someone provide a bit of guidance here? The correct command line
>> and some explanation of where the parameter come from would be great.
>> I have the latlong coordinates needed to do the conversion. I'm assuming
>> the EOF is just a control-D.
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
