[GRASS-user] gislock: Permission denied
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Tue Jun 13 11:14:28 EDT 2006
Hello,
since last week I get this error, if I want to start grass61.
as user baliola:
>grass61
>Cleaning up temporary files.....
>ERROR: LOCATION_NAME not set
>Starting GRASS ...
>///.gislock: Permission denied
>ERROR: /usr/local/grass-6.1.cvs/etc/lock:
>baliola is currently running GRASS in selected mapset. Concurrent use not
>allowed.
>grass61 /data1/grassdb/spearfish57/PERMANENT
>Starting GRASS ...
>allowed.
I searched the GRASS ML and found a few mails with hints but applied them
without success:
- Search for .gislock and deleted them
- remove /usr/local/grass... and reinstalled with fresh cvs
- applied chmod on grassdb
I definitely have no .gislock file on my system anymore, but nevertheless I
receive this promt.
as root I get:
>grass61
login UI with locations only - no mapset are displayed - I can create a new
mapset, login and work successfully. However trying to access other mapsets
results in this error:
>GRASS 6.1.cvs (spearfish57):/home/baliola > Error in startup script: ERROR:
MAPSET PERMANENT - permission denied
    while executing
"close $input"
    (procedure "MapCanvas::zoom_gregion" line 7)
    invoked from within
"MapCanvas::zoom_gregion $mon"
    (procedure "MapCanvas::create" line 39)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 71)
    invoked from within
"Gm::create"
    (procedure "main" line 29)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 518)
sorry, if I missed any relevant mails - thanks in advance for any hint.
cheers Martin
