[GRASS-user] grass instalation on fc4
M S
mseibel at gmail.com
Fri Jun 16 14:07:48 EDT 2006
you're trying to compile GDAL or GRASS?
On 6/16/06, Ana Soares <tiobrothercamarada at gmail.com> wrote:
> Hi :-)
> I get this problem :
> [root at ana gdal-1.3.1]# ./configure --without-grass
> --with-hdf4=/usr/local/hdf4.2r1 --with-libtiff=internal
> --with-geotiff=internal --with-python --without-ogdi --without-libgrass
> --enable-shared
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking target system type... i686-pc-linux-gnu
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for a sed that does not truncate output... /bin/sed
> checking for egrep... grep -E
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for /usr/bin/ld option to reload object files... -r
> checking for BSD-compatible nm... /usr/bin/nm -B
> checking whether ln -s works... yes
> checking how to recognise dependent libraries... pass_all
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking dlfcn.h usability... yes
> checking dlfcn.h presence... yes
> checking for dlfcn.h... yes
> checking how to run the C++ preprocessor... g++ -E
> checking for g77... no
> checking for f77... no
> checking for xlf... no
> checking for frt... no
> checking for pgf77... no
> checking for fort77... no
> checking for fl32... no
> checking for af77... no
> checking for f90... no
> checking for xlf90... no
> checking for pgf90... no
> checking for epcf90... no
> checking for f95... f95
> checking whether we are using the GNU Fortran 77 compiler... yes
> checking whether f95 accepts -g... yes
> checking the maximum length of command line arguments... 32768
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for objdir... .libs
> checking for ar... ar
> checking for ranlib... ranlib
> checking for strip... strip
> checking if gcc static flag works... yes
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC
> checking if gcc PIC flag -fPIC works... yes
> checking if gcc supports -c -o file.o... yes
> checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
> yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> configure: creating libtool
> appending configuration tag "CXX" to libtool
> checking for ld used by g++... /usr/bin/ld
> checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
> yes
> checking for g++ option to produce PIC... -fPIC
> checking if g++ PIC flag -fPIC works... yes
> checking if g++ supports -c -o file.o... yes
> yes
> appending configuration tag "F77" to libtool
> checking for f95 option to produce PIC... -fPIC
> checking if f95 PIC flag -fPIC works... yes
> checking if f95 supports -c -o file.o... yes
> checking whether the f95 linker (/usr/bin/ld) supports shared libraries...
> yes
> checking for dlopen in -ldl... yes
> checking for nanosleep in -lrt... yes
> checking for main in -lm... yes
> checking for ANSI C header files... (cached) yes
> checking assert.h usability... yes
> checking assert.h presence... yes
> checking for assert.h... yes
> checking fcntl.h usability... yes
> checking fcntl.h presence... yes
> checking for fcntl.h... yes
> checking for unistd.h... (cached) yes
> checking dbmalloc.h usability... no
> checking dbmalloc.h presence... no
> checking for dbmalloc.h... no
> checking for dlfcn.h... (cached) yes
> checking for stdint.h... (cached) yes
> checking limits.h usability... yes
> checking limits.h presence... yes
> checking for limits.h... yes
> checking locale.h usability... yes
> checking locale.h presence... yes
> checking for locale.h... yes
> checking values.h usability... yes
> checking values.h presence... yes
> checking for values.h... yes
> checking float.h usability... yes
> checking float.h presence... yes
> checking for float.h... yes
> checking whether byte ordering is bigendian... no
> checking for 64bit integer type... long long
> checking for 64bit file io... yes
> checking for int... yes
> checking size of int... 4
> checking for long... yes
> checking size of long... 4
> checking for int8... no
> checking for int16... no
> checking for int32... no
> checking native cpu bit order... lsb2msb
> checking for vprintf... yes
> checking for _doprnt... no
> checking for vsnprintf... yes
> checking for snprintf... yes
> checking for atoll... yes
> checking for gmtime_r... yes
> checking for localtime_r... yes
> checking for setlocale... yes
> checking for local include/lib path... none
> configure: checking whether we should include thread/mutex support......
> thread safe support disabled.
> checking for deflateInit_ in -lz... yes
> using pre-installed libz
> checking for pg_config... no
> checking for PostgreSQL... GRASS support disabled.
> checking for ffopen in -lcfitsio... no
> libcfitsio not found - FITS support disabled
> checking for Mopen in -lcsf... no
> checking csf.h usability... no
> checking csf.h presence... no
> checking for csf.h... no
> using internal csf code.
> checking for nc_open in -lnetcdf... no
> libnetcdf not found - netCDF support disabled
> checking for png_set_IHDR in -lpng... yes
> checking png.h usability... yes
> checking png.h presence... yes
> checking for png.h... yes
> using pre-installed libpng.
> using internal TIFF code.
> using internal GeoTIFF code.
> checking for jpeg_read_scanlines in -ljpeg... yes
> checking jpeglib.h usability... yes
> checking jpeglib.h presence... yes
> checking for jpeglib.h... yes
> checking for width_in_blocks in jpeglib.h... yes
> using pre-installed libjpeg.
> checking for DGifOpenFileName in -lgif... yes
> using pre-installed libgif.
> ogdi support disabled.
> checking for FMEObjects... no
> checking for SDreaddata in -lmfhdf... no
> checking for SDreaddata in -lhdf4... no
> configure: error: HDF4 support requested with arg /usr/local/hdf4.2r1, but
> neither hdf4 nor mfhdf lib found
> But :
> ]# rpm -Uhv hdf-4.2r1-6.fc4.i386.rpm
> Preparing... ###########################################
> [100%]
> package hdf-4.2r1-6.fc4 is already installed
> 2006/6/16, M S <mseibel at gmail.com>:
> > hi. i'm on FC4 too and have compiled from source. if there's anything
> > i can help with please let me know.
> > On 6/16/06, Ana Soares < tiobrothercamarada at gmail.com> wrote:
> > > Hello :-)
> > I am trying to install grass on fc4... but i can t find any of the
> > packages on synaptic.... Isn t there ant repostories i should add ??
> > plesase help me :(
> > http://www.public.asu.edu/~iullah/fc4.html<http://www.public.asu.edu/%7Eiullah/fc4.html>
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060616/0d07f1d8/attachment.html
