[GRASS-user] r.proj error
Hamish
hamish_nospam at yahoo.com
Sun Jun 18 21:54:57 EDT 2006
gary wrote:
> Well 14 hours later, my r.proj bombed.
I'm not surprised!
> Unfortunately, I don't have an email account set up for root. Any
> ideas on why this bombed?
why are you running GRASS as root? That's probably not a very good idea.
FWIW, in GRASS 6.1 r.proj has been changed to be run as a normal module,
i.e. no email; has 0-100% progress meter.
> BTW, is there some easy way to keep the projected resolution from
> exceeding the input resolution? Given the nearest neighbor algorithm,
> there is nothing to be gain by interpolation (I assume).
Remember it will likely be slighlty rotated and stretched as well.
> Output:
> Cols: 90240 (90240)
> Rows: 201058 (201058)
> North: 4224601.960000 (4224601.960000)
> South: 4023544.200000 (4023544.200000)
> West: 513581.640000 (513581.640000)
> East: 603821.510000 (603821.510000)
> ew-res: 0.999999
> ns-res: 0.999999
90240 x 201058 = 18 billion cells, at least 72 gig of data. ouch.
set the target resolution a bit lower,
> Input:
> Cols: 3608 (3608)
> Rows: 6546 (6546)
> ew-res: 0.000278
> ns-res: 0.000278
0.000278 deg lat * 1852m/naut mi. * 60 naut mi./degree = 30.9m
( *cos(lat) for longitude )
in target location:
g.region res=30 -a
> Allocating memory and reading input map... 100%
> Projecting... WARNING: error writing null row 190379
> ERROR: error writing output map
> You have new mail in /var/spool/mail/root
maybe your computer is one step ahead of you, try:
less /var/spool/mail/root
you may also try 'r.proj -n' (similar to 'i.rectify -c'?)
Hamish
