[GRASS-user] bwidget
Maciek Sieczka
werchowyna at epf.pl
Wed Jun 21 11:06:39 EDT 2006
Paolo,
On Wed, 21 Jun 2006 15:57:30 +0200
Paolo Cavallini <cavallini at faunalia.it> wrote:
> Markus Neteler wrote:
> > Paolo Cavallini wrote on 06/21/2006 02:50 PM:
> >> If they're not executable, I get:
> >> Error in startup script: can't find package BWidget 1.2.1
> >> while executing
> >> "package require -exact BWidget 1.2.1"
> >> (file "/usr/lib/grass-6.1.cvs/etc/gm/gm.tcl" line 23)
Just to make things clear, do you mean the tcl files
in /usr/local/grass-6.1.cvs/bwidget ?
I really never have had them executable, and all was fine. Strange.
> >> BTW, with latest cvs I get:
> >> GRASS 6.1.cvs (Toscana):~ > Error in startup script: can't read
> >> "monitor_zooms(1,1,n)": no such variable
> >> while executing
> > ... no such error here.
> The only (unrelated?) error I could spot in ./configure is:
> checking whether to use GLw... yes
> checking for location of GLw includes...
> checking for GL/GLwMDrawA.h... no
> checking for X11/GLw/GLwMDrawA.h... no
> configure: error: *** Unable to locate GLwM includes.
> For the rest, compilation seems to run smoothly, and this is the first
> time I see this error.
> Any hints?
I don't have this error at ./configure, unless I specify
--with-glw=yes, not having the GLw installed. Please note GLw is not
enabled by default. If you you haven't requested it, the error you
are getting is strange.
I also wonder what we need GLw for in Grass anyway? It's not even
mentioned on http://grass.itc.it/grass60/source/REQUIREMENTS.html nor
in README and INSTALL files. I've never used it.
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
