[GRASS-user] clip points & lines with feature?
M S
mseibel at gmail.com
Thu Jun 22 07:11:45 EDT 2006
i had no success with v.select too. do layers play into this at all? i
have a vector "clipper" that i want to use to select and put overlapping
points into a new vector. no matter how i run it, the output is zero
features.
On 6/22/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> On Wed, 21 Jun 2006 11:46:03 -0400
> "M S" <mseibel at gmail.com> wrote:
> > in the v.overlay dialog... in only see line and area for input vector
> > #1, and area for vector #2.
> > can it be used to clip points?
> clip points? you mean select them rather
> v.select
> > basically i have lines/streets and
> > points that i need to clip out to run the v.net.steiner fucntion on.
> Maciek
> CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej
> cenie, zapoznaj si? z nasz? ofert?.
> ZAPRASZAMY
> www.skarpatravel.pl
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060622/11934643/attachment.html
