[GRASS-user] FW: How to allow a file browser dialog in shells
cripts
Patton, Eric
epatton at nrcan.gc.ca
Thu Jun 22 09:38:15 EDT 2006
Thanks Hamish and Markus for the reference. Is there a way to have the file
loader dialog box open in a certain directory like $GISDBASE, for instance?
~ Eric.
-----Original Message-----
To: grassuser at grass.itc.it
Sent: 6/22/2006 8:55 AM
Subject: Re: [GRASS-user] FW: How to allow a file browser dialog in
shellscripts
Hamish wrote on 06/22/2006 11:35 AM:
>Eric wrote:
>>I'm trying to create a script to load plan ascii files as input. I'm
>>unfamiliar with all of the possible variations for the gisprompt
>>parameter structure. I want to allow the user to browse the Mapset to
>>load each ascii file.
>add to the option definition:
>#% gisprompt: old_file,file,input
>e.g. m.proj.
>>While we're on the topic, can anyone explain why there are usually
>>several gisprompt parameters allowed for in most Grass shell scripts?
>>What do all these mean?
>somewhere deep in the programmers' manual or lib/gis/parser.c ...
>from memory:
>old/new - whether to open map/file browser; checks that it won't
overwrite
>element - the directory in $MAPSET, if applicable
>prompt - mostly unused nowadays?
Here is the list:
http://mpa.itc.it/markus/grass61progman/
-> File List <http://mpa.itc.it/markus/grass61progman/files.html>
-> paerser.c
http://mpa.itc.it/markus/grass61progman/parser_8c-source.html#l00326
Markus
Markus
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
