[GRASS-user] Importing vectors (polygons) without building topology
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Jun 23 01:28:05 EDT 2006
Hernán De Angelis napisa?(a):
> Dear list,
> I have a bunch of PostGIS layers (polygons) that I want to import into GRASS.
> These polygons represent palaeogeographic features and therefore they
> necessarily overlap over some regions (different entities are distinguished
> by attributes in the attribute table). Since v.in.ogr automatically builds
> topology by default, a secondary layer is generated during import where the
> the overlapping sectors of the polygons are cut and stored. Whereas this
> might be useful for a wide range of applications it is certainly not
> desirable in my case, since it destroys the palaeogeographic representation.
> My question is therefore: how can I import these shapefiles and avoid topology
> building at the same time? I understand that exporting the tables as text and
> importing them using v.in.ascii might be an option, but I would rather prefer
> to preserve the carefuly designed attribute tables as they are, without
> having to regenerate them.
> I have been thinking in this problem during a couple of days without coming to
> a decent solution, so I hope someone can give me a hint on this.
> I am using GRASS 6.0.2 RC4 in OpenSuSE 10.0.
> Thanks in advance
> Hernán
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
v.external
