[GRASS-user] Makefile:22: include/Make/Platform.make: No such file or directory
Maciek Sieczka werchowyna at epf.pl
Fri Jun 23 12:18:30 EDT 2006
On Fri, 23 Jun 2006 14:08:15 +0200
Markus Neteler <neteler at itc.it> wrote:
> On Fri, Jun 23, 2006 at 01:47:50PM +0100, David wrote:
> > Thanks to those who replied to my previous thread i.vpoints. I have
> > been trying the CVS install and hit errors in the make process, I
> > get similar errors using both 6.0-CVS and 6.1-CVS snapshots from
> > http://grass.itc.it/faq/cvs_howto.html
> > cd /usr/local/src/grass61
> > tar xzf grass-6.1.cvs_src_snapshot_2006_06_18.tar.gz
> > export
> > CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
> > cvs login cvs up -dP
> > cd grass-6.1.cvs_src_snapshot_2006_06_18
> > CFLAGS="-ggdb -march=k8 -Wall" ./configure \
> > 	--with-tcltk-includes=/usr/include/tcl8.4 \
> > 	--with-motif \
> > 	--with-motif-includes=/usr/include/qt3 \
> > 	--with-readline \
> > 	--with-cxx \
> > 	--with-odbc \
> > 	--with-sqlite \
> >  	--with-freetype \
> > 	--with-postgres-includes=/usr/include/postgresql \
> > 	--with-freetype-includes=/usr/include/freetype2 \
> > 	--with-ffmpeg \
> > 	--with-ffmpeg-includes=/usr/include/ffmpeg \
> > 	--enable-64bit \
> > 	--with-libs=/usr/lib64 \
> > 	--with-ffmpeg \
> > 	--with-tiff \
> > 	--with-blas \
> > 	--with-lapack \
> > 	2>&1 | tee config_log.txt
> > make distclean
> here is the problem: don't run 'make distclean' because it will remove
> the configuration again.
Also, don't build with blas and lapack, they are not used for anything.
Read REQUIREMENTS.html.
Motif id needed for xanim only - do you need it?
And no need to specify several of those switches explicitely - many are
turned on by default. See ./configure --help | grep "default: yes"
Cheers,
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
