[GRASS-user] shortest distance between 2 segments?
Michael Barton
michael.barton at asu.edu
Fri Jun 23 21:32:55 EDT 2006
V.distance?
Michae
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: A Horacio Samaniego <horacio at unm.edu>
> Date: Tue, 20 Jun 2006 16:27:07 -0600 (MDT)
> To: <grassuser at grass.itc.it>
> Subject: [GRASS-user] shortest distance between 2 segments?
> I have a question on the network functionality on GRASS
> Is there any way to query the shortest path between two vector segments in
> GRASS?
> I have the following 2 segments in the DB
> [local] roads=# select
> cat,fename,fetype,fraddl,fraddr,toaddl,toaddr,road_type from
> nm_bernalillo_alb where cat=18607 OR cat=12697;
> cat | fename | fetype | fraddl | fraddr | toaddl | toaddr | road_type
> 12697 | Amherst | Dr | 901 | 900 | 1013 | 1016 | 8
> 18607 | Monroe | St | 901 | 900 | 999 | 998 | 8
> (2 rows)
> I get the following output with no results because I believe you are
> required to specify points :
> GRASS 6.0.0 (albers):~ > echo "1 18607 12697" | v.net.path
> input=nm_bernalillo_alb output=path2 afcolumn=road_type
> Building graph:
> Registering arcs ... 100%
> Flattening the graph ... done.
> Graph was built.
> WARNING: No point with category 18607
> WARNING: No point with category 12697
> Attributes:
> cat - path unique category assigned by module
> id - path id (read from input)
> fcat - from point category
> tcat - to point category
> sp - result status:
> 0 - OK, path found
> 1 - node is not reachable
> 2 - point of given category does not exist
> cost - travelling costs (on the network, not to/from network)
> fdist - the distance from first point to the network
> tdist - the distance from the network to second point
> WARNING: 2 points of given category missing
> Building topology ...
> 0 primitives registered
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids: Topology was built.
> Number of nodes : 0
> Number of primitives: 0
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
> thanks!
> H
> Horacio Samaniego
> Department of Biology
> University of New Mexico
> Albuquerque, NM. 87131
> Phone: (505) 277-3431
> Fax: (505) 277-0304
> (http://www.unm.edu/~horacio)
