[GRASS-user] i.spectral and gnuplot
Sat Jun 24 10:00:32 EDT 2006
Stuart Edwards wrote:
> I'm trying to run i.spectral which of course requires gnuplot.  I
> have gnuplot 4 installed (via fink) but i.spectral can't see it and
> asks for it to be installed.  I made GRASS_GNUPLOT = /sw/bin but that
> didn't help.  I'm running 6.1cvs on OSX 10.4.6.  Any suggestions on
> how to make gnuplot visible to i.spectral would be much appreciated.
There is a gratuitous check for whether gnuplot is in the path:
	#check if present
	if [ ! -x "`which gnuplot`" ] ; then
	    echo "$PROG: gnuplot required, please install first" 2>&1
	    exit 1
	fi
Remove that check from the i.spectral script. It actully uses
$GRASS_GNUPLOT to invoke it.
