[GRASS-user] [GRASSLIST:1131] Re: SQLite connection in GUI?
Mon Jun 26 03:22:40 EDT 2006
Jonathan Greenberg wrote:
> Is there any quick way to allow for sqlite to be a legit db driver in the
> v.db commands (under the gui, I think it works fine via command line)?  Why
> was it removed (or was it never a selection option)?  After 5 days of trying
> to (unsuccessfully) get postgresql working under cygwin, sqlite took all of
> 2 seconds to download and install, so it's an attractive option for Windows
> grass users...
does "db.drivers -p" list sqlite?
If not, GRASS wasn't configured and compiled with SQLite support.
IMO, all GRASS 6.1 binary packages should be including support for
SQLite.
If db.drives shows it, use db.connect to set it as the active db
connection. (see the db.connect help page)
db.connect -p
db.tables -p
Hamish
