[GRASS-user] i.spectral and gnuplot
Stuart Edwards
sedwards2 at cinci.rr.com
Mon Jun 26 22:18:50 EDT 2006
Francesco
Ok -- that was straight forward (in the grand scheme of things) --
thanks. Now when I run i.spectral the following error is returned:
line 229: gnuplot: command not found
Is this a path problem on my part or something in the script? Is
$GNUPLOT (from line 229) the same as GRASS_GNUPLOT (the
environmental variable)? Wish I knew more about this! Thanks for
any advice.
Stuart
On Jun 26, 2006, at 12:00 PM, francesco wrote:
> Stuart,
> I don't know about Mac's binaries, but i.spectral is actually a
> script and it is accessible using any editor. Check your script
> folder in your grass distribution and remove the gnuplot check
> strings which Glynn pointed out.
> Cheers,
> Francesco
> At 15.43 26/06/2006, you wrote:
>> Glynn, Hamish
>> Thanks for looking into it. Since I'm hooked on Lorenzo's binaries
>> I'll have to wait for his next update.
>> Stuart
>> On Jun 24, 2006, at 10:00 AM, Glynn Clements wrote:
>>> Stuart Edwards wrote:
>>>> I'm trying to run i.spectral which of course requires gnuplot. I
>>>> have gnuplot 4 installed (via fink) but i.spectral can't see it and
>>>> asks for it to be installed. I made GRASS_GNUPLOT = /sw/bin but
>>>> that
>>>> didn't help. I'm running 6.1cvs on OSX 10.4.6. Any suggestions on
>>>> how to make gnuplot visible to i.spectral would be much
>>>> appreciated.
>>> There is a gratuitous check for whether gnuplot is in the path:
>>> #check if present
>>> if [ ! -x "`which gnuplot`" ] ; then
>>> echo "$PROG: gnuplot required, please install first"
>>> 2>&1
>>> exit 1
>>> fi
>>> Remove that check from the i.spectral script. It actully uses
>>> $GRASS_GNUPLOT to invoke it.
>>> Glynn Clements <glynn at gclements.plus.com>
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
