WG: [GRASS-user] OGR Import Error for shapes with Fieldtype DATE
Düster Horst Horst.Duester at bd.so.ch
Fri Jun 30 04:57:11 EDT 2006
Now with attachment!!!       :()
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS® Koordination
Rötistrasse 4
CH-4501 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
-----Ursprüngliche Nachricht-----
Von: Düster Horst [mailto:Horst.Duester at bd.so.ch]
Gesendet am: Freitag, 30. Juni 2006 09:33
An: 'grassuser at grass.itc.it'
Betreff: [GRASS-user] OGR Import Error for shapes with Fieldtype DATE
I try to import the attched shape with v.in.ogr but the process breakes with
the following error message:
v.in.ogr dsn=/gis_data/natpol.shp output=test min_area=0.0001 snap=-1
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: natpol
Column type not supported (NEW_DATE)
Column type not supported (ARCHIVE_DA)
DBMI-DBF driver error:
Incompatible value type.
Error in db_execute_immediate()
The reason of this error seems to be the fields NEW_DATE and ARCHIVE_DA.
These two fields are of type DATE. The same problem appears with the ogr
Import functionality og QGIS 0.8. Datatype DATE is an approved type for ESRI
Shapefiles.
Is it a known bug? Does exists a suitable workaround?
Dr. Horst Düster
Kanton Solothurn
Rötistrasse 4
CH-4501 Solothurn
www.sogis.so.ch
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060630/4b9f1cfc/sogis.obj
