[GRASS-user] ./configure error with gdal-grass-1.3.1.2
David
dpleydel at univ-fcomte.fr
Fri Jun 30 10:55:48 EDT 2006
Here's another of those gdal-grass plugin don't work threads.
My ld.so.conf reads like this
/usr/X11R6/lib
## Grass 6.0.2
## /usr/lib/grass/lib
## Grass 6.1.cvs
/usr/local/src/grass61/grass-6.1.cvs_src_snapshot_2006_06_24/lib
## Proj Library
/usr/lib
## gdal-config file
/usr/bin
## geos-config
/usr/local/bin
I have run ldconfig as root.
Then I did
./configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/src/grass61/grass-6.1.cvs_src_snapshot_2006_06_24
which produced the following output
_24
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for g++ -shared ... yes
user supplied gdal-config (/usr/local/bin/gdal-config)
using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/src/grass61/grass-6.1.cvs_src_snapshot_2006_06_24 requested, but libraries not found!
In config-log there were two hints at errors, the first...
configure:1999: $? = 0
configure:2002: test -s conftest.o
configure:2005: $? = 0
configure:2023: result: none needed
configure:2041: gcc -c -g -O2 conftest.c >&5
conftest.c:2: error: syntax error before 'me'
configure:2047: $? = 1
configure: failed program was:
| #ifndef __cplusplus
| choke me
| #endif
The second...
configure:2461: $? = 0
configure:2464: test -s conftest.o
configure:2467: $? = 0
configure:2493: g++ -c -g -O2 conftest.cc >&5
conftest.cc: In function 'int main()':
conftest.cc:13: error: 'exit' was not declared in this scope
configure:2499: $? = 1
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h. */
| int
| main ()
| exit (42);
| return 0;
How might I overcome these errors?
Many thanks
David
