[GRASSLIST:10646] Re: r.fillnulls
giglio.antonio at katamail.com giglio.antonio at katamail.com
Wed Mar 1 05:11:35 EST 2006
> Da: Maciek Sieczka <werchowyna at epf.pl>
> Data: Sat, 25 Feb 2006 09:46:03 +0100
> A: "giglio.antonio at katamail.com" <giglio.antonio at katamail.com>
> Oggetto: [GRASSLIST:10565] Re: r.fillnulls
> On Fri, 24 Feb 2006 16:28:02 +0000
> "giglio.antonio at katamail.com" <giglio.antonio at katamail.com> wrote:
> > Hi, i used r.in.srtm for building a DEM. I have joined images (1°x1°
> > squares) using r.patch, and now i'm trying to fill "no data" holes in
> > the map i obtained. I think to use r.fillnulls, but have the
> > following error:
> > r.fillnulls input=input_name output=srilanka.dem tension=40.
> > smooth=0.1 Using tmp file r_fillnulls_3464
> > Locating and isolating NULL areas...
> > GRASS_INFO_ERROR(3474,1): invalid ellipsoid i
> > \a in file PROJ_INFO in PERMANENT
> Please post what Grass version you are using, g.proj -p output and the
> contents of your_location/PERMANENT/PROJ_INFO file. Maybe it will help
> to indicate the problem.
> <snip>
> Maciek
> W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
first of all thank you for the reply!...than here are the informations you ask me for:
- i'm using versions 6.0.1 and 6.1cvs (updated today), both with the same problem;
- g.proj -p output is:
-PROJ_INFO-------------------------------------------------
proj       : ll
ellps      : i
-PROJ_UNITS------------------------------------------------
unit       : degree
units      : degrees
meters     : 1.0
-PROJ_INFO file contents:
proj: ll
ellps: i
i have the same problem also using v.in.ogr
________________________________________________________________________
SERVIZIO VOICE: TELEFONA e INVIA SMS dal tuo computer a tariffe vantaggiose!
Scopri come telefonare e videochiamare gratis da pc a pc.
http://voice.repubblica.it
