[GRASSLIST:10653] Re: r.proj takes a very long time / does not complete
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Mar 1 09:27:44 EST 2006
Hello Hamish
On Wed, 1 Mar 2006, Hamish wrote:
>>> That would be very handy if r.proj could estimate the best output
>>> resolution as well. I remember there was some discussion about
>>> completely replacing r.proj warper with gdal warper. Any news?
>> The way I see it is that they perform two different, complementary
>> functions. gdalwarp is useful if you have a whole map/image you want
>> to  convert to a new projection and not lose any of the data. r.proj
>> is useful  if you already have a region of interest you're working on
>> in the GIS, and  want to import only the portion of the larger
>> map/image that covers this region, at the same resolution and with the
>> same boundaries etc. as your  existing maps in your location.
>> Does that make sense?
> (again, sorry for very late responses)
> I don't know if this goes for r.proj method=nearest,bilinear,cubic as
> well, but for i.rectify the idea was to use the GDAL warp *API*, not
> the gdalwarp program.
Hmm yes. I suppose my point may have been (can't remember too well as was
long ago!) that in the usage scenario for r.proj that I suggested, the
less advanced r.proj algorithm would tend to be adequate for what would
likely be a smaller area to be re-projected etc. The limitations came more
into play when you were re-projecting a whole map, which gdalwarp was
better suited for anyway.
But yeah no technical argment at all against improving the r.proj warping
by using GDAL functions.
Paul
