[GRASSLIST:10713] Re: Viewing raster maps a native resolution
    David Finlayson
    david.p.finlayson at gmail.com
    Fri Mar  3 10:11:49 EST 2006
I'd like to hear how people do poster-size output myself. So far, I've
done mostly figure-sized output and d.out.png is fine for that. You
can set up the monitor to roughly a multiple size of what you need.
Then use d.out.png to export the monitor to a PNG file. Finally, add
the map decorations necessary for your map in Inkscape or Gimp. On my
(physical) monitor I can stretch the Xmonitor out to about 1200
pixles. d.out.png res=2 will double that, so I have a png file with
2400 pixels on a side. At 300 dpi that is an 8-inch figure (high-res
publication). At 150 dpi, which is good enough for most plotters, that
is a picture 16 inches across. I don't know how to go larger than that
for a full-sized poster.
David
On 3/3/06, Jason Horn <jhorn at bu.edu> wrote:
> I'm having problems producing good maps with GRASS, especially
> detailed shaded reliefs.  When rasters are viewed on screen, unless
> they are displayed at native resolution, they look terrible because
> there is no anti-aliasing in grass monitors.  I figure, the only
> solution is to set up the monitor size and zoom level so that ever
> raster cell take up exactly 1 pixel on the screen. Does anyone know
> of a way to do this?  Is there some other way to produce maps with
> anti-aliasing?
> Thanks,
> - Jason
David Finlayson
U.S. Geological Survey
Coastal and Marine Geology
831-427-4757
831-427-4748 (fax)
USGS Pacific Science Center
400 Natural Bridges Drive
Santa Cruz, CA  95060
