[GRASSLIST:10729] Re: How to save to PERMANENT
Huidae Cho grass4u at gmail.com
Fri Mar 3 14:57:11 EST 2006
"g.list type=rast mapset=other_mapset" will help you.
Huidae Cho
On Fri, Mar 03, 2006 at 09:14:06AM -0800, Michael Rensing wrote:
> OK, that makes sense, but when I start in the PERMANENT mapset, I don't see any
> of the maps in my other mapset. Does that mean there's some kind of permission
> problem, or do I need to remember the names of the other maps, or ...
> Thanks again,
> Michael
> Huidae Cho wrote:
> >Try "g.copy from=map at mapset to=map" in the PERMANENT mapset.  The to= option
> >of
> >g.copy does not support @MAPSET, so you must run grass with the PERMANENT
> >mapset.
> >Huidae Cho
> >On Wed, Mar 01, 2006 at 10:15:56PM -0800, Michael Rensing wrote:
> >>Hello; a real noob question: once I have a map layer I want to keep/share,
> >>how do I copy it into the PERMANENT location? When I tried r.copy, I got an
> >>error that a file does not exist.
> >>TIA
> >>Michael
