[GRASSLIST:10746] Re: draw gps co-ordinates with a varying
circle around them
Hamish
hamish_nospam at yahoo.com
Sun Mar 5 21:05:58 EST 2006
> > I hope I explain my problem properly. I have managed, with your
> > help, to visualise my gps data with v.neigbors, where v.neigbors
> > lets me specify the size of the neigborhood diameter and then counts
> > how many gps points fall within each neigborhood.
> > What I like to do now is to visualise gps data which has long and
> > lat, plus a value for the size of the neigborhood around each long -
> > lat co-ordinate, e.g.:
> > 51.298895 | 1.071705 | 0.1
> > I don't want grass to count the frequency of gps co-ordinates which
> > fall into the neigborhood, as all of them have already been
> > eliminated from the data. So all I want grass to do essentially is
> > to visualise gps co-ordinates with varying circles around them.
> > Thank you for pointing me into the right direction.
> > Cheers,
> > Phil
> Give d.vect.thematic a try.
for bubble plots also try 'd.vect.chart ctype=pie' with only one data
column, size column.
or try 'v.buffer bufcol=' (sometimes buggy)
Hamish
