[GRASSLIST:10784] awk not found on Mac osx, Repost
Dave Kent dkent at sasktel.net
Tue Mar 7 00:11:40 EST 2006
I posted this some time ago.  Markus responded with a change which
has been incorporated into CVS code.
However, this hasn't helped things for me as I still am getting a
problem with "awk required"
I am using 6.1 CVS with Lorenzo's binaries (06 March 06 ) on a
macintosh OS 10.4.
When I try to add a database column I get:
v.db.addcol map=CondieHead layer=1 'columns=Elev varchar(10)'
csh: /sw/bin/init.csh: No such file or directory.
: awk required, please install awk/gawk first
This suggests awk is absent.  When I invoke awk from the grass
command line, I get:
GRASS 6.1.cvs (SaskNad83UTM) > awk
Usage: awk [-f programfile | 'program'] [-Ffieldsep] [-v var=value]
[files]
This suggests that awk is present as it lists  the help line.
I have not installed awk/gawk.  It is present in the Mac OSX
installation at    /usr/bin/awk
Are there some environmental or other settings I need to set so that
Grass sees awk?
This also happens when opening a QGIS connection from the display
manager.
Thanks
Dave
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060306/81234480/attachment.html
