[GRASSLIST:10814] Re: SRTM data transformation
Wed Mar 8 04:36:09 EST 2006
> OK, one final question: are the z-Values also adapted to the new
> region?  I was told, that in my case the difference should be about
> 40-50m.
r.proj acts in 2D only AFAIK. You will want to use the r.to.vect trick:
export all the cell midpoints coordinates & reproject individually with
PROJ4's cs2cs software*. Then reimport, and convert back to a raster
with v.to.rast. I don't know if there is an easier way.
[*] hint: OUT_PROJ="`g.proj -jf`"
Hamish
