[GRASSLIST:10851] Re: Bus Error in g.remove
William Kyngesburye
woklist at kyngchaos.com
Thu Mar 9 10:14:44 EST 2006
Except that I reported this bug last August, and it happens with
6.0.1 and 6.1CVS. I haven't tried 6.0.2 yet.
On Mar 9, 2006, at 1:33 AM, Hamish wrote:
> Just a thought,
> in the past weeks some code was changed to replace system calls with
> their C equivalents. Maybe this has something to do with it. I can't
> connect to the CVS-web interface currently to check.
> Look for recent changes in:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/
> Hamish
> On Wed, 08 Mar 2006 21:04:54 -0600
> Dave Kent <dkent at sasktel.net> wrote:
>> Thanks for the insight. I went back to the Nov 05 binaries and
>> Janurary CVS version and things work. That will be fine for now. I
>> guess learning how to build wouldn't be a bad thing.
>> Thanks for your help.
>> Dave
>> On Mar 8, 2006, at 6:40 PM, William Kyngesburye wrote:
>>> This is probably the same bug Michael Barton reported yesterday
>>> (#4152) and I reported last August (#3585). Specifically, when
>>> GRASS is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
>>> support. It's probably happening for you in Tiger because Lorenzo
>>> builds with Panther compatibility - either on Panther, or on Tiger
>>> using the Panther SDK. A Tiger-only build (GCC 4) is unaffected.
>>> It's a strange bug - I can build GRASS with GDAL without Postgres
>>> support, then update GDAL to include Postgres support and it still
>>> works. It's only when GDAL has Postgres support *at the time GRASS
>>> is built*. I've tried various combinations of static and dynamic
>>> Postgres libraries (and the exact same ones used for Postgres
>>> support in GRASS) and other options in GDAL and GRASS and GRASS
>>> with/without its own Postgres support.
>>> On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
>>>> I am using Grass 6.1CVS on Macintosh with the most recent
>>>> Macintosh binaries.
>>>> g.remove gives the following error.
>>>> child killed: bus error
>>>> while executing
>>>> "exec -- $cmd --tcltk"
>>>> (procedure "execute" line 4)
>>>> invoked from within
>>>> "execute g.remove "
>>>> (menu invoke)
>>>> This started quite suddenly, possibly consistent with messing with
>>>> AWK post I had yesterday.
>>>> I get the same error with g.copy, g.rename but not g.list
>>>> I have reinstalled the binaries and the application.
>>>> There was a not too similar message in the archives which relates
>>>> to the environmental variable file being corrupted. I cannot find
>>>> this file and haven't tried removing it.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
