[GRASSLIST:9] breaking polylines2
Téglásy Örs orsteglasy at yahoo.com
Sat Mar 11 05:25:10 EST 2006
 I found the v.segment command to break my polylines (see previous letter), but it doesn't really work for me. Somehow it doesn't find any primitives on the source layer:
 v.segment input=lineament_plines_clean output=lineament_segments llayer=1
 Building topology ...
 Registering lines:
 0 primitives registered
 Building areas:
 0 areas built
 0 isles built
 Attaching islands:
 Attaching centroids: Topology was built.
 Number of nodes     :   0
 Number of primitives:   0
 Number of points    :   0
 Number of lines     :   0
 Number of boundaries:   0
 Number of centroids :   0
 Number of areas     :   0
 Number of isles     :   0
 0  points read from input
 0 points written to output map (0 lost)
 0 lines read from input
 0 lines written to output map (0 lost)
 Here are the layer statistics (those plines really exist):
 v.info map=lineament_plines_clean layer=1
  | Layer:    lineament_plines_clean         Organization:                     |
  | Mapset:   ors                            Source Date:                      |
  | Location: mecsek                         Name of creator:                  |
  | Database: /home/ors                                                        |
  | Title:        |
  | Map Scale:  1:1                                                            |
  | Map format: native                                                         |
  |   Type of Map:  Vector (level: 2)                                          |
  |   Number of points:       0               Number of areas:      0          |
  |   Number of lines:        1963            Number of islands:     0          |
  |   Number of boundaries:   0               Number of faces:      0          |
  |   Number of centroids:    0               Number of kernels:    0          |
  |   Map is 3D:              0                                                |
  |   Number of dblinks:      0                                                |
  |   Projection: x,y (zone 0)                                                 |
  |            N: 104257.387    S: 47125.596                                   |
  |            E: 631169.085     W: 567345.920                                 |
  |            B: 0.000         T: 0.000                                       |
  |   Digitize threshold: 0.00000                                              |
  |   Comments:        |
 What is the problem? Any idea?
 Thanks a lot!
 Örs Téglásy
  Kontakt:
  Téglásy Örs
+36 (20) 385-5928
Brings words and photos together (easily) with
  PhotoMail  - it's free and works with Yahoo! Mail.
  Kontakt:
  Téglásy Örs
+36 (20) 385-5928
 Yahoo! Mail
 Use Photomail to share photos without annoying attachments.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060311/a0b3c182/attachment.html
