[GRASSLIST:20] Re: what to use instead of s.cellstats?
Sat Mar 11 23:50:09 EST 2006
> I have a grid of sites. I would like to sum up the values of these
> sites hundred by hundred. According to a grass article I should be
> able to do this using s.cellstats  -sum command but it doesn't exist
> any longer under Grass60. Any idea what to use instead of it?
GRASS 5.4 still works fine, load the data into there, use s.cellstats,
then restart in GRASS 6 and use the new raster map. Raster maps are
backwards compatible, you may need to edit out any 3D lines in the
mapset's WIND file if you want to go GRASS 6 -> GRASS 5.
Hamish
