[GRASSLIST:50] Re: [GRASS5] Re: New GIS Manager adds transparency to layers
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Mon Mar 13 13:45:30 EST 2006
Hello Michael,
I've been playing with gism and there are some points:
When I make the display window too big (like, the size of my monitor),
some times transparency won't work, some times it wil....
If I change region in terminal (say, g.region rast=myrast), and then
just ask for a redraw, nothing happens! I have to unselect the layers,
"draw" a blank screen and then select the layers and draw again.
Something similar was happening when I was testing some shaded relief
maps. I was changing vertical exaggeration, but the name of the map
was the same, so if I just asked for a redraw, nothing would happen.
I guess this is because the _name_ of the map being displayed hasn't changed.
About the region thing, how about two mor buttons: one for "region to
rast" and one for "region to vector" ?
BTW, you said that the ppm way of displaying would make things
faster... personally, I felt it slower.
all the best
Carlos
On 3/13/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> Michael,
> Sorry; I should have tried this first… no problem when I startup from my
> $HOME (login) directory. Typically I like to startup GRASS from my GRASS
> database directory. Is this the anticipated behavior or should it be
> considered a 'bug'?
> Thanks for your feedback and great work!
> Tom
> Thomas Adams wrote:
> > Michael,
> > Where is GRASS/new display manager going to look for the .tmp
> > directory? In the directory GRASS is started from; one's $HOME
> > directory; other?
> > Thanks,
> > Tom
> > Michael Barton wrote:
> >> Something similar has just been reported on some lab computers
> >> running GRASS
> >> under Cygwin. Maybe it's a different issue, though because it only
> >> happened
> >> with a version of init.sh that automatically runs gism2. It seems to
> >> run OK
> >> if launched manually.
> >> Your GRASS in a non-standard location might be an issue. I'm not sure
> >> where
> >> the working directory error comes from. Is it a TclTk error (buttons
> >> run,
> >> cancel, details) or another kind of error (xwindows, bash, etc..)?
> >> The GIS Manager display works by creating PPM files in a temp directory
> >> within your working GRASS mapset--set by g.tempfile. If you don't have
> >> access to such a .tmp directory, you will have problems.
> >> Let me know if any of these gives you a clue to what is wrong.
> >> Michael
> >> On 3/10/06 7:22 PM, "Thomas Adams" <Thomas.Adams at noaa.gov> wrote:
> >>> Michael,
> >>> I have installed the GRASS 6.1 CVS release dated 2006_03_04
> >>> and followed your instructions in the README in
> >>> _http://www.public.asu.edu/~cmbarton/files/grass_gismgr/
> >>> <http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr/>_gism_rc4_20060307.
> >>> tgz.
> >>> First off, the installation using the old d.m works fine ‹ no errors.
> >>> When I try the new gis.m, the interface tries to come up, but it stalls
> >>> with an error Dialog that reads "Error getting working directory name:
> >>> no such file or directory". If I select the Error Dialog 'OK' button,
> >>> the GIS manager completes its startup. However, if I select a raster
> >>> map
> >>> to display and click on the refresh button (labeled: "Display active
> >>> layers in the current region") in the "Map Display 1" window, I get the
> >>> same Error Dialog as I got when I first started up the new GIS Manager
> >>> (gis.m). Also, from the time of the startup of the GIS Manager, the
> >>> 'status indicator' in the lower left of the "Map Display 1" window
> >>> shows: "please wait..." ‹ this never goes away.
> >>> Interestingly, if I select the NVIZ button, there is no problem
> >>> displaying the raster I selected; so, NVIZ seems OK, but the raster map
> >>> will never display in 2-D in the "Map Display 1" windowŠ
> >>> Also, when I try to use the Init.sh file from gism_rc4_20060307.tgz, I
> >>> get shared library problems: "libgrass_gis.so cannot open shared object
> >>> file: No such file or directory" ‹ even though the library is in the
> >>> GRASS lib directory. I should mention that due to system constraints,
> >>> the entire GRASS distribution and other libraries (GDAL, PROJ, etc.)
> >>> are
> >>> in a non-standard location.
> >>> A final question: should I be using the gis.m file from
> >>> gism_rc4_20060307.tgz? I have tried both with and withoutŠ
> >>> I'm running on a Redhat Linux system, FWIWŠ
> >>> Tom
> >>>> I¹ve just finished phase 2 of the GIS Manager update and it¹s pretty
> >>>> exciting. At first glance, it looks a lot like the one I¹ve been
> >>>> working on and have in the CVS now, but with a couple of important
> >>>> exceptions. One is that transparency is now supported for all GRASS
> >>>> layers.
> >>>> The second will probably generate the most discussion, so I¹m ready to
> >>>> duck and run for cover. Now GRASS is consistent with other GIS
> >>>> programs and more intuitive (as much as I am skeptical about that
> >>>> term) in that the uppermost layer in the layer tree is also the top
> >>>> map in the display. Related to this, new layers insert directly above
> >>>> the currently selected layer instead of at the bottom of the layer
> >>>> tree.
> >>>> The main changes come Œunder the hood¹ of this version of the GIS
> >>>> Manager. It uses g.pnmcomp to composite a set of maps (each rendered
> >>>> as *.PPM files) into a visual display. One of the results is that now
> >>>> GRASS is significantly faster in adding new layers, turning layers on
> >>>> and off, and changing layer attributes‹only the new or changed layer
> >>>> needs to be rendered; the others will just be re-composited into a
> >>>> display from existing PPM files. This all happens in a GRASS .tmp
> >>>> directory, so that it doesn¹t clutter up your home directories. The
> >>>> other important thing about this new architecture is that it makes
> >>>> GRASS even less dependent on the xdriver and PNGdriver for
> >>>> visualization. GRASS can become more easily portable to different OS¹s
> >>>> and GUI frameworks. It is also more scriptable. You can write a script
> >>>> that will create a complete, multilayered map, and output it to a
> >>>> graphics file.
> >>>> One consequencer of this new architecture is that the GIS Manager does
> >>>> not currently support display output to PNG files. With GDAL (required
> >>>> for many GRASS features) and ghostscript installed, it does support
> >>>> output to PPM/PNM, TIF, JPG, BMP, EPS, and PDF.
> >>>> Command line usage is still supported in several ways‹the old
> >>>> xterminal is still there, there is the new command console, and you
> >>>> can add command layers to the layer tree and display them.
> >>>> You can see a screen shot of semi-transparent soil vector areas
> >>>> overlaying a raster shaded relief map at
> >>>> _http://www.public.asu.edu/~cmbarton/files/grass_screenshots/gism2-2.jpg
> >>>> <http://www.public.asu.edu/%7Ecmbarton/files/grass_screenshots/gism2-2.jpg>
> >>>> _
> >>>> I¹ve committed all changes to the CVS. For those of you with binary
> >>>> versions of GRASS who would like to try it, I¹ve posted packages you
> >>>> can use to replace your current GIS Manager on my website. For full
> >>>> functionality, you need a version of grass that is dated
> >>>> 21-February-2006 or later. For those of you with a slightly earlier
> >>>> version, I made a second package with all functionality minus
> >>>> transparency. Here are the links.
> >>>> New GIS Manager files
> >>>> <_http://www.public.asu.edu/~cmbarton/files/grass_gismgr/
> >>>> .tgz>
> >>>> New GIS Manager files for people with recent, but pre-21 February 2006
> >>>> binaries.
> >>>> pre_02-21.tgz>
> >>>> Enjoy
> >>>> Michael
> >>>> ______________________________
> >>>> Michael Barton, Professor of Anthropology
> >>>> School of Human Evolution and Social Change
> >>>> Arizona State University
> >>>> Tempe, AZ 85287-2402
> >>>> USA
> >>>> voice: 480-965-6262; fax: 480-965-7671
> >>>> www: http://www.public.asu.edu/~cmbarton
> >>>> <http://www.public.asu.edu/%7Ecmbarton>
> >> School of Human Evolution & Social Change
> >> Tempe, AZ 85287
> >> WWW - http://www.public.asu.edu/~cmbarton
> >> Phone: 480-965-6262
> >> Fax: 480-965-7671
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL: thomas.adams at noaa.gov
> VOICE: 937-383-0528
> FAX: 937-383-0033
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
