[GRASSLIST:73] Re: Buffer distance map around points.
Luca Casagrande luca.casagrande at gmail.com
Tue Mar 14 05:26:32 EST 2006
Hi and welcome to GRASS ml!
For your problem, the starting point is this:
http://grass.itc.it/grass61/manuals/html61_user/v.buffer.html
For this problem, you could also use the GRASS plugin inside QGIS...
Luca
Alle 03:50, martedì 14 marzo 2006, David Jaramillo ha scritto:
> Hi everyone,
> I'm new in Grass, i have a vector map with points, and i need to create  a
> new (buffer) map that groups with colors the ranges of distance from each
> point.
> What commands and parameters can i use ?
> Thanks,
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
