[GRASSLIST:100] Re: Bus Error in g.remove
Michael Barton
Michael.Barton at asu.edu
Tue Mar 14 14:21:38 EST 2006
Huidae and Dave,
This cropped up on the Mac binaries. I didn't realize that it was affecting the Win binaries too. Lorenzo Moretti solved it. It had to do with changed to how gdal interfaces with GRASS.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
-----Original Message-----
Sent: Sun 3/12/2006 11:36 PM
To: Dave Kent
Cc: Hamish; kyngchaos at kyngchaos.com; grasslist at baylor.edu
Subject: [GRASSLIST:30] Re: Bus Error in g.remove
OK, it doesn't matter whether you installed an older GRASS version or not
because if the code is working, the bus error has nothing to do with the change
that I made recently. Maybe it's related to PostgreSQL or GDAL compilation?
Huidae Cho
On Sun, Mar 12, 2006 at 03:51:37PM -0600, Dave Kent wrote:
> Hi:
> I ran the program. It listed every file and directory in the system. I
> aborted it after a few minutes before it finished. There were no error
> messages.
> Note that I have reinstalled older GRASS version that works and the system is
> not the same as when the problem occurred.
> Hope this is helpful.
> Dave
> On Mar 9, 2006, at 9:48 PM, Huidae Cho wrote:
> >I've made those changes in mid-February this year. Could you try running
> >the
> >following code and let me know what this does? Don't worry, it's like "find
> >dir" command.
> >cc -o list list.c -Wall
> >./list /
> >---<list.c>---
> >#include <stdio.h>
> >#include <string.h>
> >#include <unistd.h>
> >#include <sys/types.h>
> >#include <sys/stat.h>
> >#include <dirent.h>
> >static int recursive_list(const char *path);
> >int
> >main(int argc, char *argv[])
> > if(argv[1])
> > return recursive_list(argv[1]);
> > return 1;
> >static int
> > DIR *dirp;
> > struct dirent *dp;
> > struct stat sb;
> > char path2[1024];
> > if(lstat(path, &sb))
> > return 1;
> > if(!S_ISDIR(sb.st_mode))
> > printf("file: %s\n", path);
> > return 0;
> > if((dirp = opendir(path)) == NULL)
> > return 1;
> > while((dp = readdir(dirp)) != NULL)
> > if(dp->d_name[0] == '.')
> > continue;
> > sprintf(path2, "%s/%s", path, dp->d_name);
> > recursive_list(path2);
> > closedir(dirp);
> > printf(" dir: %s/\n", path);
> > return 0;
> >On Thu, Mar 09, 2006 at 08:33:26PM +1300, Hamish wrote:
> >>Just a thought,
> >>in the past weeks some code was changed to replace system calls with
> >>their C equivalents. Maybe this has something to do with it. I can't
> >>connect to the CVS-web interface currently to check.
> >>Look for recent changes in:
> >> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/
> >>Hamish
> >>On Wed, 08 Mar 2006 21:04:54 -0600
> >>Dave Kent <dkent at sasktel.net> wrote:
> >>>Thanks for the insight. I went back to the Nov 05 binaries and
> >>>Janurary CVS version and things work. That will be fine for now. I
> >>>guess learning how to build wouldn't be a bad thing.
> >>>Thanks for your help.
> >>>Dave
> >>>On Mar 8, 2006, at 6:40 PM, William Kyngesburye wrote:
> >>>>This is probably the same bug Michael Barton reported yesterday
> >>>>(#4152) and I reported last August (#3585). Specifically, when
> >>>>GRASS is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
> >>>>support. It's probably happening for you in Tiger because Lorenzo
> >>>>builds with Panther compatibility - either on Panther, or on Tiger
> >>>>using the Panther SDK. A Tiger-only build (GCC 4) is unaffected.
> >>>>It's a strange bug - I can build GRASS with GDAL without Postgres
> >>>>support, then update GDAL to include Postgres support and it still
> >>>>works. It's only when GDAL has Postgres support *at the time GRASS
> >>>>is built*. I've tried various combinations of static and dynamic
> >>>>Postgres libraries (and the exact same ones used for Postgres
> >>>>support in GRASS) and other options in GDAL and GRASS and GRASS
> >>>>with/without its own Postgres support.
> >>>>On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
> >>>>>I am using Grass 6.1CVS on Macintosh with the most recent
> >>>>>Macintosh binaries.
> >>>>>g.remove gives the following error.
> >>>>>child killed: bus error
> >>>>> while executing
> >>>>>"exec -- $cmd --tcltk"
> >>>>> (procedure "execute" line 4)
> >>>>> invoked from within
> >>>>>"execute g.remove "
> >>>>> (menu invoke)
> >>>>>This started quite suddenly, possibly consistent with messing with
> >>>>>AWK post I had yesterday.
> >>>>>I get the same error with g.copy, g.rename but not g.list
> >>>>>I have reinstalled the binaries and the application.
> >>>>>There was a not too similar message in the archives which relates
> >>>>>to the environmental variable file being corrupted. I cannot find
> >>>>>this file and haven't tried removing it.
