[GRASSLIST:140] Question about re-projecting points imported from Postgres
Thomas Adams
Thomas.Adams at noaa.gov
Wed Mar 15 13:19:23 EST 2006
List:
I have a Lat-Long location into which I have successfully imported
points from Postgres (a further question about this further below). What
I want to do is to re-project the points into a Lambert Conic Conformal
location using v.proj. When I try to do this, it does not work — it
seems as though GRASS does not know how to do this. I have been able to
do this successfully with points imported using v.in.ascii. It seems I
am missing something, either conceptually or procedurally…
The further question about using v.in.db, the 'key' parameter in the
documentation claims this is a string, which makes since to me, but when
v.in.db is run, GRASS complains that an integer is needed. I'm guessing
the integer that's supplied is the column/field number (beginning with
'1'); if true, this seems to be inconsistent by what the 'x', 'y', and
'z' fields require — just a thought.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
