[GRASSLIST:168] Re: Question about re-projecting points imported
from Postgres
Thomas Adams
Thomas.Adams at noaa.gov
Thu Mar 16 08:51:50 EST 2006
David,
Yes, I had the LCC location created already. I've gone through this
process many times, but never from data brought into GRASS via Postgres.
Can it be that I missed a step after I imported the data using v.in.db
into my lat-long location?
Tom
David Finlayson wrote:
> Have you already created your Lambert Conformal Conic location? If
> not, remember that v.proj pulls data into the current location from
> somewhere else, projecting the data in the process if necessary.
> On 3/15/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>> List:
>> I have a Lat-Long location into which I have successfully imported
>> points from Postgres (a further question about this further below). What
>> I want to do is to re-project the points into a Lambert Conic Conformal
>> location using v.proj. When I try to do this, it does not work — it
>> seems as though GRASS does not know how to do this. I have been able to
>> do this successfully with points imported using v.in.ascii. It seems I
>> am missing something, either conceptually or procedurally…
>> The further question about using v.in.db, the 'key' parameter in the
>> documentation claims this is a string, which makes since to me, but when
>> v.in.db is run, GRASS complains that an integer is needed. I'm guessing
>> the integer that's supplied is the column/field number (beginning with
>> '1'); if true, this seems to be inconsistent by what the 'x', 'y', and
>> 'z' fields require — just a thought.
>> Tom
>> Thomas E Adams
>> National Weather Service
>> Ohio River Forecast Center
>> 1901 South State Route 134
>> Wilmington, OH 45177
>> EMAIL: thomas.adams at noaa.gov
>> VOICE: 937-383-0528
>> FAX: 937-383-0033
> David Finlayson
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
