[GRASSLIST:183] Re: imagery classification tools for classification of terrian types
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Mar 16 16:07:11 EST 2006
Markus,
Thanks for the tips. I have been able to get these two commands that you
suggested to work in the past... but this time no luck:
i.gensigset trainingmap=terrain.train group=terrain subgroup=terrain
signaturefile=terrain.sig
Finding training classes ... 100%
3 classes
Reading image data ... 100%
Clustering class 1, with 103499 pixels
Warning: Removed a singular subsignature; number 1; 9 remain
Warning: Removed a singular subsignature; number 1; 8 remain
Warning: Removed a singular subsignature; number 1; 7 remain
Warning: Removed a singular subsignature; number 1; 6 remain
Warning: Removed a singular subsignature; number 1; 5 remain
Warning: Removed a singular subsignature; number 1; 4 remain
Warning: Removed a singular subsignature; number 1; 3 remain
Warning: Removed a singular subsignature; number 1; 2 remain
Warning: Removed a singular subsignature; number 1; 1 remain
Error: unreliable clustering
try a smaller initial number of clusters
Warning: Removed a singular subsignature; number 1; -1 remain
Subclasses = 0; Rissanen = 0.000000; Solution: Number of subclasses is 0
Clustering class 2, with 732 pixels
Clustering class 3, with 45545 pixels
.. could this be a result of my training data being too coarse ?
this results in a segfault in i.smap ....
thoughts?
Dylan
On Thursday 16 March 2006 12:43 pm, Markus Neteler wrote:
> Dylan,
> try
> i.gensigset
> i.smap
> works FAR better IMHO...
> The training areas may not be too small (few pixels).
> good luck
> Markus
> On Thu, Mar 16, 2006 at 12:29:49PM -0800, Dylan Beaudette wrote:
> > Hi everyone,
> > Attempting to do some simple geomorphologic classification based on
> > parameters calculated from a DEM.
> > I have tried a couple permutations of i.cluster i.gensig, and i.maxlik
> > without success here are the commands that I used in my tests:
> > #1. training data based classification
> > i.group group=terrain subgroup=terrain
> > input=slope_n,er9,profc,maxic,minic,longc
> > r.digit --->terrain.train
> > i.gensig trainingmap=terrain.train group=terrain subgroup=terrain
> > #results in:
> > 100%
> > 3 classes.
> > Calculating class means ...
> > 100%
> > Calculating class covariance matrices...
> > 100%
> > Signature [1] not invertible.
> > Signature [2] not invertible.
> > Signature [3] not invertible.
> > Writing signature file [terrain.sig]
> > #i.maxlik dies with:
> > ERROR: Can't read signature file [terrain.sig].
> > 2. unsupervised classification:
> > i.cluster group=terrain subgroup=terrain sigfile=terrain.sig classes=5
> > #results in:
> > Iteration 1: % Convergence: 100.00 (0s elapsed, 0s left)
> > i.maxlik group=terrain subgroup=terrain sigfile=terrain.sig
> > class=terrain.class
> > #results in a map with all cells set to 1
> > I am using GRASS6.1-CVS and all of my input maps are FCELL or DCELL ....
> > could this be the cause of my problems?
> > As a side note, this little adventure was started after reading a past
> > paper by Roger Bivand on the use of R for a simple cluster-based approach
> > to classifying terrain [1]. In his paper he goes over the aspects of
> > getting data to move between GRASS and R, leaving the interpretation of
> > the results to a geomorphologist. The R-approach seemed ideal, however I
> > thought that I would try it with the GRASS classification commands first.
> > [1] Roger Bivand. Integrating GRASS 5.0 and R: GIS and modern statistics
> > for data analysis. Internal Paper (?)
> > Thanks!
> > Dylan Beaudette
> > Soils and Biogeochemistry Graduate Group
> > University of California at Davis
> > 530.754.7341
Dylan Beaudette
530.754.7341
