[GRASSLIST:199] Re: trouble using v.in.ascii
Vishal Mehta
vishalm1975 at gmail.com
Fri Mar 17 03:00:37 EST 2006
Hi all,
ok i was able to get the points vector file done- silly syntax mistake on my
part-sorry.
But i could use some input on my attempts to connect my data dbf file to the
vector points file as layer 2.
What i did is, that i prepared a dbf file in Windows, then brought it into
my /dbf folder in Linux/Grass. Now this file is recognized when i do
db.describe(below):
GRASS 6.0.1 (ncdc):~/Desktop/NCDC > db.describe -c Data
ncols:11
Column 1: WMOID
Column 2: CITY
Column 3: YEAR
Column 4: YDAY
Column 5: TMAX
Column 6: TMIN
Column 7: TDAY
Column 8: RAIN
Column 9: VPD
Column 10: SRAD
Column 11: DAYLEN
BUT, the column 'WMOID' which i want to use as key, has suddenly become
float (it was integer when i made it in windows), and in fact all numeric
columns are assigned double precision now when they were not originally. How
do i rectify this, since to identify a key tolink my vector points to this
data file, the key column should be integer?
I dont know postgresql, mysql etc, therefore i'm trying things this way..
thanks,
vishal
On 3/17/06, David Finlayson <david.p.finlayson at gmail.com> wrote:
> Breezy also has the "flip" command (search synaptic) for converting
> line endings.
> -David
> On 3/16/06, Stefan Istvan <stefi at geohidroterv.hu> wrote:
> > On Fri, 2006-03-17 at 11:30 +0530, Vishal Mehta wrote:
> > > Hi all,
> > > I'm trying to bring in a comma separated text file as a point vector
> > > file in GRASS using v.in.ascii, before i try to link it to a large
> > > 33Mb dbf data file.
> > > The csv file looks like this with 39 rows and i removed the header
> > > because grass60 (on Ubuntu breezy) does not have the skip option in
> > > the v.in.ascii command: the columns are WMOID, cityname, Latitude and
> > > Longitude. I want to use the WMOID as 'cat' in order to link my dbf
> > > data later.
> > > 420710,AMRITSAR,31.63,74.86
> > > 421010,PATIALA,30.33,76.46
> > > 421310,HISSAR,29.16,75.73
> > > 421820,DELHI,28.58,77.20
> > > 423390,JODHPUR,26.30,73.01
> > > 423480,JAIPUR,26.81,75.80
> > > 423690,LUCKNOW,26.75,80.88
> > > 424100,GAUHATI,26.10,91.58
> > > I Tried the following command and got the error:
> > > cat reformat/STATIONS2.dat | v.in.ascii output=stations2 fs=','
> > > columns='cat int, name(varchar(30), y double, x double' x=4 y=3 cat=1
> > > WARNING: DOS text format found, attempting import anyway
> > > Maximum input row length: 39
> > > Maximum number of columns: 4
> > > Minimum number of columns: 4
> > > column: 1 type: integer
> > > column: 2 type: string length: 18
> > > column: 3 type: double
> > > column: 4 type: double
> > > DBMI-DBF driver error:
> > > SQL parser error in statement:
> > > create table stations2 ( cat int, name(varchar(30), x double, y
> > > double )
> > > Error in db_execute_immediate()
> > > ERROR: Cannot create table: create table stations2 ( cat int,
> > > name(varchar(30), x double, y double )
> > > I also get the same error with
> > > v.in.ascii input=reformat/STATIONS.csv output=gstations fs=',' skip=1
> > > columns='cat int, label(varchar(30), y double, x double' x=4 y=3 cat=1
> > There is an additional "(" sign in your columns definition. You should
> > write columns='cat int, label varchar(30), y double, x double'.
> > The other problem maybe that your file is in MSDOS format, but it could
> > be that it doesn't bother Grass. Try to use dos2unix command to convert
> > it to unix format.
> > Regards,
> > Istvan
> David Finlayson
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060317/51a0d6cf/attachment.html
