[GRASSLIST:230] Re: [GRASS5] Built-in vector documentation extended
Thomas Adams Thomas.Adams at noaa.gov
Fri Mar 17 15:45:19 EST 2006
Markus,
Great! Thank you very much (now I know I'm not insane, well... as it
relates to this topic anyhow). This is the conclusion I had come to,
that is, that I needed to change the Postgres table. My problem is that
the Postgres table schema is not under my control, so I'll have to
create a new one.
You asked about:
x=-1*lon
-> x=lon (what does -1*lon mean? The command wants a column *name*)
Pretty funny actually, in the 'wisdom' of the database designers, they
assumed the longitude would always be in the Western Hemisphere at least
for the *application* of the database values. So, negative longitude
values can not be used. The "x=-1*lon", as it turns out, actually will
convert the positive longitude values to negative in the SQL query -- it
works.
Cheers!
Tom
Markus Neteler wrote:
> Thomas,
> On Fri, Mar 17, 2006 at 02:55:52PM -0500, Thomas Adams wrote:
>> Michael,
>> Your instructions did not help... I'm sorry to be a bother about this,
>> so, I'll restate the problem I'm having.
>> I have a Postgres database with a table called 'location', which
>> consists of meteorological observation points with lat-long coordinates
>> along with various other attributes:
>> CHARACTER|lid
>> CHARACTER|county
>> CHARACTER|coe
>> CHARACTER|cpm
>> CHARACTER|detail
>> DOUBLE PRECISION|elev
>> CHARACTER|hdatum
>> CHARACTER|hsa
>> CHARACTER|hu
>> DOUBLE PRECISION|lat
>> DOUBLE PRECISION|lon
>> CHARACTER|lremark
>> DATE|lrevise
>> CHARACTER|name
>> CHARACTER|network
>> CHARACTER|rb
>> CHARACTER|rfc
>> DATE|sbd
>> CHARACTER|sn
>> CHARACTER|state
>> CHARACTER|waro
>> CHARACTER|wfo
>> CHARACTER|wsfo
>> CHARACTER|type
>> CHARACTER|des
>> CHARACTER|det
>> INTEGER|post
>> CHARACTER|stntype
>> CHARACTER|tzone
>> Please notice that only one field is type integer, namely, the 'post'
>> field; it is a boolean (1 or 0).
> ... so 'post' is unsuitable. key must be an unique ID column.
>> When I use the GRASS v.in.db command:
>> v.in.db driver=pg database=host=dell3-tir,dbname=hd_ob6tir
>> table=location x=-1*lon y=lat z=elev key=1 where=rfc='OHRFC'
>> output=locations
> Funny, that v.in.db accepts this input:
> -> database="host=dell3-tir,dbname=hd_ob6tir"
> x=-1*lon
> key=1
> -> key=columname (apparently you don't have a column with unique
>                   ID, so you will have to add one with
>                   ALTER TABLE ..., see db.execute)
>> I am forced to supply key=???; the only thing that works for me is key=0
>> or key=1, etc. since I have no integer field with unique integer values.
> If you don't have it, you will have to modify the table.
> There is no other way IMHO.
> All which is done here it telling v.in.db how the columns are named.
> Any calculation must be done beforehand in the table, using SQL
> or other ways (depends on the data storage).
> Apparently the manual page of v.in.db is unclear, I would appreciate
> suggestions how to improve it.
> Markus
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
