[GRASSLIST:232] Re: Importing Tiger Data with v.in.ogr
J. Brian Adams
brian.adams at fandm.edu
Fri Mar 17 16:25:11 EST 2006
In response to all.
I am trying to import raw Tiger Data. Using awk to extract the
significant features is what I will have to do. It is what I did
when I was a student of John MacKenzie's at Delaware in the mid 90's
(so be careful of the "very old" adjective.) His instructions were
what I used when using the old v.in.tig in Grass 4 and 5. I had
assumed that v.in.ogr had eliminated this approach, and thus I was
hoping to find out if it had. The documentation v.in.ogr is
excellent for importing shape files, but it seem very limited (in my
opinion) when addressing raw Tiger Data. Thanks for all of your help.
On Mar 17, 2006, at 3:05 PM, Ed Davison wrote:
> On Fri, 2006-03-17 at 14:49 -0500, J. Brian Adams wrote:
>> I would like to create vector maps from Tiger Data. Some of these
>> are lines (Roads, Streams, ...) and some are areas (Census Block, Zip
>> Codes, ...) I have tried to use v.in. ogr but I seem to be missing
>> something in the process. What I get is a map of all of the vector
>> lines, but I am not seeing how to differentiate specific attributes.
>> Is there a tutorial or explanation on using v.in.ogr with Tiger?
> You have to extract the pieces/vectors that you want before you
> load it
> with v.in.ogr. The best source of information that I have found is a
> very old www.udel.edu source, complete with examples.
> Here is the link:
> http://www.udel.edu/johnmack/frec682/682proj3.html
> Hope it helps.
> Ed Davison
> Sr. Systems Analyst
> McCombs School of Business
> 512-232-6620 voice
J. Brian Adams
Asst. Professor of Computer Science
206 Stager Hall
Franklin & Marshall College
Lancaster, PA 17604-3003
(717) 291-3872
