[GRASSLIST:294] Re: r.out.gdal problem
    Jachym Cepicky
    jachym.cepicky at centrum.cz
    Tue Mar 21 13:40:42 EST 2006
I would say, that type=Int32 shold work fine
jachym
On Tue, Mar 21, 2006 at 06:53:50PM +0100, Wolfgang Zillig wrote:
> My raster map is from the type CELL (with a range of [0-32767]). Can I use (and
> how) r.out.gdal directly?
> Wolfgang
> Jachym Cepicky schrieb:
> >Hallo,
> >On Tue, Mar 21, 2006 at 04:59:43PM +0100, Wolfgang Zillig wrote:
> >>To make it clear, I have a georeferenced raster grafic. r.out.tiff works, and
> >>I can do successfully:
> >>C:\Documents and Settings\s0167070>gdal_translate -of GTiff -co TILED=YES -co
> >>CO
> >>MPRESS=JPEG -co JPEG_QUALITY=65 in.tif out.tif
> >>(But I have to say that I also have FWTools installed on my computer, I
> >>haven't tried with cygwin)
> >>Is it possible to export a raster file with the command given above? Grass
> >>always complains that I have to specify the "type", which I don't know.
> >Type is, what does your r.info your_map |grep "Data Type" you.
> >This will be CELL (integer), DCELL or FCELL (floating point)
> >r.out.tiff makes always integers from floating point maps. via
> >r.out.gdal's "type" option, you can specify the precision of resulting
> >raster file
> >hope, this helps
> >Jachym
> >>Wolfgang
> >>Patton, Eric schrieb:
> >>>When you say graphic, do you mean a non-georeferenced image? I'm guessing,
> >>>maybe r.out.gdal is only good for georeferenced images. Have you had any
> >>>luck trying 'gdal_translate -of JPEG input output'?
> >>>~ Eric.
> >>>-----Original Message-----
> >>>From: owner-GRASSLIST at baylor.edu
> >>>To: grasslist-en
> >>>Sent: 3/21/2006 10:18 AM
> >>>Subject: [GRASSLIST:281] r.out.gdal problem
> >>>Hello,
> >>>I somehow don't completely understand the usage of r.out.gdal. I prepared a
> >>>graphic (which is an imported tiff) with r.composite. I can export it with
> >>>r.out.tiff without any problems. But how can I use r.out.gdal to export it
> >>>as JPEG (or GTiff with TILED=YES). I always fail
> >>>to specify the correct option for the required "type". I already tried every
> >>>possibility which is listed (Byte, Int16,...), but without success. What
> >>>"type" do I have to use?
> >>>Thanks
> >>>Wolfgang
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brně
Zemědělská 3
613 00 Brno
e-mail: xcepicky at node.mendelu.cz
URL:    http://mapserver.mendelu.cz
Tel.:   +420 545 134 514
