[GRASSLIST:336] Re: gis.h problem
Glynn Clements
glynn at gclements.plus.com
Thu Mar 23 08:48:44 EST 2006
Ana Soares wrote:
> I have GRASS 6 installed, but I can't seem do have GIS library
> $ gcc main.c
> main.c:8:17: error: gis.h: No such file or directory
> Why does this happen?
> What must I do ?
GRASS doesn't install headers into the system header directories (e.g.
/usr/include), but into the GRASS directory hierarchy (e.g.
/usr/local/grass6/include). You need to use a -I switch to specify the
location, e.g.
gcc -c -I /usr/local/grass6/include main.c
GRASS is quite a complex package, and may be quite hard to use if you
are new to C programming.
