[GRASSLIST:342] Problems compiling in Fedora Core 5
Miha Staut
mihastaut at yahoo.co.uk
Thu Mar 23 10:50:05 EST 2006
I recently upgraded to Fedora Core 5. An error was reported during configure
grass 5.4 (dowloaded from the source tree) in way I was not able to build the
binary programme. See the stdout below.
[root at localhost grassbuild]# CFLAGS="-O3" LDFLAGS="-s"
/home/src/grass-5.4.0/configure --prefix=/usr/local\
--with-motif --with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include\
--with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib\
--with-cxx --with-freetype --with-freetype-includes=/usr/include/freetype2\
--without-odbc --without-dbm --with-tcltk-libs=/usr/lib\
--with-tcltk-includes=/usr/include --with-postgres --with-proj\
--with-gdal --with-nls --with-glw
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -O3 -s) works... yes
checking whether the C compiler (gcc -O3 -s) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /home/src/grass-5.4.0
checking for build directory... /home/src/grass-5.4.0/grassbuild
checking for Build Mechanism to be used... Alternate
checking how to build libraries... shared
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)...
/home/src/grass-5.4.0/configure: line 12492: syntax error: unexpected end of
file
Thanks for your help,
Miha
___________________________________________________________
Yahoo! Messenger - NEW crystal clear PC to PC calling worldwide with voicemail http://uk.messenger.yahoo.com
