[GRASSLIST:357] Re: grass libraries
    Ana Soares
    tiobrothercamarada at gmail.com
    Fri Mar 24 09:30:00 EST 2006
seabiscuit at ubuntu:/$ ls /usr/local/lib/
firmware/  python2.4/ site_ruby/
firmware  python2.4  site_ruby
$ ls /usr/lib/grass/
bin  bwidget  docs  driver  etc  fonts  include  lib  man  scripts
But I think I fixed the problem now! :)
Here's the makefile :
prot1: utils.o db_mg.o session.o main.o
    gcc -o prot1 -L/usr/lib/grass/lib utils.o db_mg.o session.o
main.o-lreadline -lcurses -lgrass_gis -lm
main.o:
    gcc -c -I /usr/lib/grass/include -L/usr/lib/grass/lib main.c
session.o:
    gcc -c session.c
db_mg.o:
    gcc -c -I /usr/lib/grass/include db_mg.c
utils.o:
    gcc -c utils.c
clean:
    rm -f *.o *~ prot1
Thanks anyway for the help! :-D
2006/3/24, marcos boullón magán <marcosboullon at gmail.com>:
> >  gcc -o prot1 utils.o db_mg.o session.o main.o -lreadline -lcurses
> > -lgrass_gis
> >  /usr/bin/ld: cannot find -lgrass_gis
> >  collect2: ld returned 1 exit status
> >  make: *** [prot1] Error 1
> Yoy forgot again the -L/usr/local/grass6/lib switch in the linking
> command (you have all the GRASS libs there, haven't you?).
> Anyway, the easiest way to start programming against theses libraries
> is reusing the code in grass6/vector/v.sample directory, in GRASS
> sourcecode. Rename your code as "main.c" and run "make" to compile.
> Unfortunately the Makefile file assumes that you managed to compile
> and build GRASS, not a trivial task (nor too dificult).
> Good luck,
> M.
> -- marcos boullón magán
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060324/2aa614cc/attachment.html
