[GRASSLIST:380] Re: GRASS 6.1CVS v.in.ascii problem
Michael Barton michael.barton at asu.edu
Sat Mar 25 12:59:38 EST 2006
I had the identical thing happen the other day using 6.1 from 11 March.
I went ahead and put it into dbf format and imported it that way, but it
should have worked through v.in.ascii.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Thomas Adams <Thomas.Adams at noaa.gov>
> Date: Fri, 24 Mar 2006 15:25:28 -0500
> To: David Finlayson <david.p.finlayson at gmail.com>
> Cc: GRASSLIST <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:372] GRASS 6.1CVS v.in.ascii problem
> David,
> Very interesting. Here are the facts:
> Using a RedHat Linux system
> Both v.in.ascii and v.proj (from lat-long location to LCC location) work
> fine with GRASS 6.0.2 built from source.
> Using GRASS 6.1CVS (dated 2006-03-18) built from source v.proj (now)
> works, but did not with the 2006-03-04 CVS build; v.in.ascii does NOT
> work -- I get errors:
> WARNING: Unparsable LatLong value found:
>          -80.04916667|39.56444444|860|49450586
>          -84.82388889|38.705|0|49450588
>          -88.50583333|39.35944444|0|49450598
>          -81.20388889|39.56305556|0|49450600
>          -82.17777778|41.34416667|0|49450616
>          -84.95972222|39.73305556|0|113805417
>          -82.92166667|40.35666667|901|113805418
>          -85.15833333|39.57361111|850|113805424
>          -80.64666667|37.72777778|1600|113805425
> My ascii data file looks like:
> -85.71666667|35.43166667|0|113805426
> -86.38055556|36.89527778|500|113805427
> -81.24583333|37.49416667|3100|113805430
> -83.63833333|40.65805556|997|113805432
> -81.71027778|38.18055556|622|113805434
> -85.04916667|41.36|861.7|49460912
> -85.67944444|40.30833333|880|113805437
> -80.76166667|37.475|2159|113805438
> The GRASS 6.0.2 interface generated v.in.ascii command with output looks
> like:
> v.in.ascii input=/home/adams/locations.txt output=locs_new format=point
> fs=| 'columns=x double precision,y double precision,z double
> precision,id int' x=1 y=2 z=3 cat=0
> Maximum input row length: 42
> Maximum number of columns: 4
> Minimum number of columns: 4
> column: 1  type: double
> column: 2  type: double
> column: 3  type: double
> column: 4  type: integer
> Building topology ...egistering lines:    1000  2000  3000  4000  5000
> 5030 primitives registered
> Building areas:
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids:
> Topology was built.
> Number of nodes     :   4468
> Number of primitives:   5030
> Number of points    :   5030
> Number of lines     :   0
> Number of boundaries:   0
> Number of centroids :   0
> Number of areas     :   0
> Number of isles     :   0
> The GRASS 6.1CVS interface generated v.in.ascii command with output (not
> including the warnings/errors, above) looks like:
> fs=| skip=0 'columns=x double precision,y double precision,z double
> That is, the comand never appears to complete...
> Tom
> David Finlayson wrote:
>> I've use v.in.ascii on text files almost daily and have not
>> experienced problems like you describe. If you can isolate the
>> problem, the developers would probably be very likely to fix the bug.
>> This is an important module.
>> As an aside, I use sqlite for my attributes, not Postgres and that may
>> be the difference between our experiences (though Postgres seems to be
>> the "preferred" database back end for GRASS)
>> David
>> On 3/16/06, David Finlayson <david.p.finlayson at gmail.com> wrote:
>>> If I understand you correctly, you have a table in Postgres that
>>> happens to contain x, y coordinates in addition to other attributes
>>> but is not a PostGIS layer. You were able to convert the X,Y points
>>> into a GRASS vector file (points) using v.in.db AND this new vector
>>> file seems to work in the lat long Location.
>>> Now when you try to project the new vector file into a LCC location it
>>> fails. What is the error you are getting? That seems like it should
>>> work.
>>> As a test, have you tried exporting the postgres table as a csv file
>>> (at least pointid, x and y) and then load the vector with v.in.ascii?
>>> You will be able to link the ID, X,Y CSV file back to the original
>>> postgres attribute table using the ID column. Does this simple vector
>>> file project?
>>> David
>>> On 3/16/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>> David,
>>>> Maybe you don't understand. The Postgres table is for points and has the
>>>> lat-long location; using v.in.db one is required to identify the x,y
>>>> location. The additional attributes are read as well, of course. I can
>>>> successfully import the Postgres table into GRASS into my lat-long
>>>> location. If I then try to re-project the points into a LCC projection
>>>> (from the LCC location), the v.proj does not seem to work. Is this what
>>>> you previously understood I was tying to do or do now?
>>>> Who would know whether or not this can be done?
>>>> Thanks for you r responsesŠ
>>>> Tom
>>>>> Ah, I understand now. I'm afraid I can't help you with this. I've only
>>>>> used databases to hold attribute information not the topology also. I
>>>>> haven't tried PostGIS yet.
>>>>> David
>>>>> On 3/15/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>>>> List:
>>>>>> I have a Lat-Long location into which I have successfully imported
>>>>>> points from Postgres (a further question about this further below). What
>>>>>> I want to do is to re-project the points into a Lambert Conic Conformal
>>>>>> location using v.proj. When I try to do this, it does not work ‹ it
>>>>>> seems as though GRASS does not know how to do this. I have been able to
>>>>>> do this successfully with points imported using v.in.ascii. It seems I
>>>>>> am missing something, either conceptually or procedurallyŠ
>>>>>> The further question about using v.in.db, the 'key' parameter in the
>>>>>> documentation claims this is a string, which makes since to me, but when
>>>>>> v.in.db is run, GRASS complains that an integer is needed. I'm guessing
>>>>>> the integer that's supplied is the column/field number (beginning with
>>>>>> '1'); if true, this seems to be inconsistent by what the 'x', 'y', and
>>>>>> 'z' fields require ‹ just a thought.
>>>>>> Tom
>>>>>> Thomas E Adams
>>>>>> National Weather Service
>>>>>> Ohio River Forecast Center
>>>>>> 1901 South State Route 134
>>>>>> Wilmington, OH 45177
>>>>>> EMAIL:  thomas.adams at noaa.gov
>>>>>> VOICE:  937-383-0528
>>>>>> FAX:    937-383-0033
>>>>> David Finlayson
>>>> Thomas E Adams
>>>> VOICE:  937-383-0528
>>>> FAX:    937-383-0033
>>> David Finlayson
>> David Finlayson
> Thomas E Adams
> VOICE: 937-383-0528
> FAX: 937-383-0033
