[GRASSLIST:390] Re: v.clean and snap feature...
Hamish
hamish_nospam at yahoo.com
Sun Mar 26 23:41:13 EST 2006
> > > I have got a vactor line layer with a lot of line splitted; in
> > > v.digit they look like this (x is red):
> > > -------x x---------
> > > If i use the v.clean command with snap feature, the vertex are
> > > being snapped on the near line and not each other.
> > > Is there a way to issue snap only between nearest vertex?
> > v.extract only the broken bits, then v.clean, v.patch?
> How use v.extract with only the broken bits?
figure out what cat numbers are for full lines and extract everything
but.
another way would be to use 'v.to.db option=length' to add a data column
with line length for each segment, then extract everything shorter than
some length with a SQL query (v.extract where="length < 100").
Hamish
