[GRASSLIST:478] Re: [GRASS5] problem with v.vol.rst
Stefán István
stefi at geohidroterv.hu
Thu Mar 30 09:40:01 EST 2006
Hello,
you are right, it was a segmentation problem. I increased npmin, and the
squares disappeared.
Best Regards,
Istvan
csütörtök 30 március 2006 09.17 dátummal ezt írta:
> Istvan,
> The module uses a segmantation procedure for datasets with more ~600
> points. If the number is less then you can interpolate without
> segmentation (i.e. "segmax=600" option should be added to the command I
> believe). Otherwise you must use higher npmin to include more points for
> interpolation within the segment.
> Hope this helps.
> Jaro
> Stefán István wrote:
> > Hello List,
> > I've been routed from the general Grass list to here with my problem.
> > I have a problem with v.vol.rst module:
> > If I set the tension parameter to high value (over 40) then after I make
> > slices from the volume, the resulted 2d raster maps will contain squares.
> > The author of the r3.to.rast module says that it could be a problem of the
> > interpolation module. In the attached jpeg you can see what I mean under
> > "squared".
> > Thank you for your help,
> > Istvan
> > __________ Informacia od NOD32 1.1458 (20060324) __________
> > Tato sprava bola preverena antivirusovym systemom NOD32.
> > http://www.eset.sk
