[GRASSLIST:507] Re: GRASS test suite
"Sören Gebbert"
soerengebbert at gmx.de
Fri Mar 31 06:30:57 EST 2006
Hi Radim,
many thanks for this info, that sounds very promising!
With those tools, the test suite should run. If not, i will make
it run!
Maybe i only need to rename some progs and stuff (awk -> gawk).
And HURRAY, md5sum is present. :)
> MSYS includes:
> basename.exe env.exe install.exe od.exe tail.exe
> bzip2.exe expr.exe install-info.exe patch.exe tar.exe
> cat.exe false.exe less.exe ps.exe tee.exe
> chmod.exe find.exe ln.exe rmdir.exe texindex.exe
> cmp.exe fold.exe ls.exe rm.exe touch.exe
> comm.exe gawk.exe m4.exe rxvt.exe tr.exe
> cp.exe grep.exe make.exe sed.exe true.exe
> cut.exe gzip.exe makeinfo.exe sh.exe uname.exe
> date.exe head.exe md5sum.exe sleep.exe uniq.exe
> diff3.exe id.exe mkdir.exe sort.exe vim.exe
> diff.exe info.exe mount.exe split.exe wc.exe
> dirname.exe infokey.exe mv.exe stty.exe xargs.exe
> > And how about the existing shell scripts in grass,
> > do they work with MSYS and GRASS with windows?
> At moment no because of the problem with variables I reported yesterday,
> but they will work soon using sh.exe from MSYS.
What does soon mean, do you provide a new zip archive?
Or can i handle this?
Sorry, i have no clue of windows ... or how qgis handles the shell.
Best regards
Soeren
> Radim
Analog-/ISDN-Nutzer sparen mit GMX SmartSurfer bis zu 70%!
Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
