[GRASSLIST:528] Re: v.in.dxf updated
Huidae Cho
grass4u at gmail.com
Fri Mar 31 15:49:30 EST 2006
On Fri, Mar 31, 2006 at 12:19:06PM +0200, Radim Blazek wrote:
> On 3/31/06, Huidae Cho <grass4u at gmail.com> wrote:
> > Hi,
> > I have updated v.in.dxf to support LWPOLYLINE and TEXT objects. LWPOLYLINE was
> > introduced after DXF R10, so the chance is good that newer DXF files will be
> > imported.
> > One problem with TEXT is that the module actually creates points and attaches
> > text labels through the "label" field in the linked table. Created tables will
> > have two fields: cat (integer), label (varchar(256)) and TEXT will be stored in
> > the label field. Since the label is actually not a graphic object in this
> > case, rotation of text and the label box (cannot determine the dimension of
> > label) are not supported.
> > Linking labels and objects is not implemented.
> It could be useful to have all the properties of elements imported to the table
> You can look into the v.in.dwg for example, it creates table with
> cat integer,
> entity_name varchar(20),
> color int,
> weight int,
> layer varchar(100),
> block varchar(100),
> txt varchar(100)
v.in.dwg imports all objects into one layer and use "d.vect where=" to display
some of them. Then what is the layer concept for? Actually, having multiple
layers (tables) in the current v.in.dxf can easily mess up dbf/ directory if
one does not use a real database. What do you think is the best approach to
this problem?
Huidae Cho
> That is useful because many people use colors for example to distinguish
> layers.
> Radim
